Re: engine running backwards?
Posted by ebbsspeed on September 28, 2005 at 06:14:40 from (69.81.27.90):
In Reply to: Re: engine running backwards? posted by Nat on September 28, 2005 at 05:32:49:
It is 180 degrees off, NOT 90. Your comment that "engine has run for years wired with cyl #1 on the flywheel end" is what tells me this. Notice that cylinders #1 and #4 in the firing order are one crankshaft rotation apart, equating to 180 distributor degrees. If you turned the distributor (body only, not rotor position) 180 degrees, and moved the wires accordingly, then it should have run. How are you determining that cylinder number 1 is on the flywheel end? Is it a number on the wire, or are you tracing it back to a specific terminal on the distributor cap? Since it is running, and the #1 wire is going to the #4 cylinder, you have many choices. You can leave it as is, and just use it. If the distributor is physically installed "wrong" meaning that it isn't in the proper position according to the book, you can pull it out and turn it to the proper location. Where you reposition it determines where the wires go back in. Best bet is as described in a few other replies. Get the #1/Fan/Front cylinder to TDC on the compression stroke (hold finger over spark plug hole and you'll feel compression) and install the distributor so BOTH the rotor in the distributor, and the body of the distributor, are "clocked" correctly. Then install the wires per the book.
Home
| Forums
Today's Featured Article -
Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
