Re: Farmall A cylinders
Posted by El Toro on September 29, 2005 at 06:00:49 from (152.163.101.13):
In Reply to: Farmall A cylinders posted by jnewark on September 29, 2005 at 04:06:24:
I think I would install a new sleeve and piston kit. Those are wet sleeves and they have a sealing ring (doughnut) at the bottom of the sleeves to prevent coolant leakage. You do not want antifreeze to leak into the crankcase. The block needs to be thoroughly cleaned of all rust and dirt where these sealing rings are installed. If the block is sludged up it should degreased and all oil passages cleaned. The crankshaft and head should cleaned too. The crankshaft needs to be measured for wear and to determine if a polishing is needed or if it needs to be ground undersize for undersize bearings. The head needs to be checked too. Worn guides, valve seat condition and thickness of valves to name a few. That student will like working on that engine. Hal
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
