Re: mold board plow question
Posted by Nat on October 12, 2005 at 04:48:42 from (64.80.110.22):
In Reply to: Re: mold board plow question posted by Jamie Harris on October 11, 2005 at 18:42:21:
The plow is a cast beam with the plow iron on the end... There's no adjustment on the plow itself.
Depth is controlled by a long lever beside the right fender that should have come with the plow. There's a straight linkage between the lever and the turned-around drawbar so the lever will raise and lower the front of the plow. This changes the angle at which it digs into the ground. Lowering the front of the plow tips the point toward the ground and makes it dig deeper.
1. You have the plow mounted correctly? The drawbar needs to be removed, turned around, and mounted backwards on the front mounting holes on the final drive housings. It needs to pivot up and down freely.
2. You have the depth control? If you don't have the depth control, the plow is useless.
Post a Followup
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
