Wits End - Leaking Oil
Posted by Farmall Frank on October 25, 2005 at 15:07:23 from (69.76.151.187):
First, I cleaned the engine real good. Then, I got a oil tracer/UV light as suggested earier to find a leak, and it looks like most is coming from the oil pan gasket. This is the 3rd gasket I have installed in one year!! Oil is dripping off various pan bolts, and I am pretty sure the gasket isn't sealing since I can see oil leaking down the pan between several bolts and the pan. Even used permatex on the pan (not the engine side) last time, but still! There's a breather tube on the right side. Could oil be coming from that? I have removed the distributer and can see oil leaking down the side of the engine from the pushrod chamber access plate on the right side of the engine, which is attached to the breather tube. The gasket must be bad, so I will replace that gasket but am not sure if oil should be behind that plate. Is oil being forced out the breather because oil is building up behind the access plate? I'm losing about one quart per 2 hours. This is making me real grumpy. Anybody have any hints on what I am missing or what I can do to fix this leak?
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
