Re: TD6?
Posted by ted 492 on November 14, 2005 at 17:38:27 from (67.2.45.26):
In Reply to: Re: TD6? posted by El Toro on November 14, 2005 at 08:42:44:
early td6 had four cylinders,no glow plugs and indeed did start on gas and switched over to diesel. these were a gem to run provided everything pertaining to starting was just so. I must confess i once started mine using jumper cables on diesel...what a racket!!!
  • Re: TD6? El Toro 17:59:48 11/14/05 (0)
Post a Followup
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
