Re: 544 deisel- a little more wisdom please- long
Posted by K.B.-826 on November 25, 2005 at 17:42:42 from (209.163.30.83):
In Reply to: Re: 544 deisel- a little more wisdom please- long posted by dave from MN on November 25, 2005 at 13:45:34:
Dave, sounds like you're gaining on it. Needing three hours plugged in on a day like today is 100% normal and to be expected, nothing will ever change that. Look at the side of your injection pump. See the lower arm, which has the fuel control cable attached to it? Now, do you see a plunger-like thing to the rear of this arm? As you pull the cable back, the lower arm contacts that plunger. When the arm just contacts that plunger, you are in the start-up position, You should be able to feel the arm hit the plunger as you pull the cable, if your cable slides nice and free. When the cable is pulled to the shut-off position, the arm should depress that plunger into it's bore. Now, to check this, start the engine and place the thottle lever in the low idle position. Pull the cable back until the lower arm just contacts the plunger. At this point, your engine should speed up to 1900 RPM. If not, you can adjust the plunger either forward or backward by means of the two lock nuts on the outside of it's bore. Like Chris said, you need to learn the exact moment to push the cable back forward, depending on the temp. Sometimes you need to hold it in the start-up position for a few seconds, especially if the engine is very cold, sometimes pushing it forward right away helps. One thing does seem obvious, these engines with that particular pump are very difficult to restart right after a failed start.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
