h transmission update and nuther question or two
Posted by tn terry t on December 11, 2005 at 19:14:03 from (205.188.117.73):
if you remember i had a transmission lock up and grinding feeling pto shaft well seems that someone had been in the main shaft cause yep you guessed it one of those little needle found its way between the constant mesh gear and the main shaftgear. bye the way none was missing from the bearing when i took it out anyway i have this ole heffer spread out all over the shop now so here is the questions . how much wear on the slider and running gears are exceptible before i need to replace them? these i have are all rounded appox. 3/16 inch so what you fellers think about ordering used gears sight-un seen? any kind of help is deeply appreciated terry t
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
