Long Post
Posted by Keith-OR on December 11, 2005 at 22:14:30 from (207.200.116.203):
In Reply to: C engine locked up posted by toomannycases on December 11, 2005 at 20:53:45:
Toomannycases, have you made sure that there is no remaining water in #4 cylinder. If there is any water PB Blaster and tran fluid will just float on top. take air hose and with an air noozle with long tube blow out any and all water in #4 cylinder. then put in your stuff to free it up, if after week or so it still not turning over, then remove valve cover, loosen rocker arm assembly(so valves will be closed in all cylinders) fill #4 with oil,clear up to sparkplug. Make an adapter with grease zerk on it, to screw into the spark plug hole. Screw in this adapter, use grease gun to pump grease into cylinder, Grease gun will produce some where between 1500 to 2000 psi, which should push piston downward...HTH
Keith & Shawn
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
