Re: FOLLOW-UP ON SHORT
Posted by Bob M on December 13, 2005 at 11:40:44 from (151.190.254.108):
In Reply to: FOLLOW-UP ON SHORT posted by RANGEL on December 13, 2005 at 10:27:49:
Rangel - Safety first: Put on safety glasses before proceeding!
While the chances are vanishingly small, there still exists a remote possibility of scattering sparks or the battery rupturing whenever you are working around batteries and starters!!
Now that we've got safety covered, if you have jumper cables I’d proceed this:
Disconnect the UNGROUNDED battery cable at both the battery and the starter switch. (Leave the GROUNDED cable attached to both the battery and the tractor frame.)
Have an assistant hold one end of the jumper cable firmly on the copper contact button on the starter. Now clamp the other end of the jumper cable to the battery post - expect a healthy spark when you make the connection! If the starter doesn’t spin the instant you make contact, disconnect the jumper at the battery.
Good luck!!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
