Re: Smokin' H
Posted by Slappy on December 18, 2005 at 03:43:11 from (70.149.246.67):
In Reply to: Smokin' H posted by Eric Allen on December 17, 2005 at 23:46:40:
I assume you have done all of the easy fixes - engine is well-tuned, used additives to un-stick rings, cleared all the improtant passages, etc - and have concluded that the problem will require more than a band-aid. My personal preference would be to do a complete overhaul. After all, if the top end is that worn, can the bottom be far behind? In the long run you"ll save money and be happier in the meanwhile. At the very least measure the journal and rod clearances so you know what you"re getting yourself into. That being said, I understand that for a lot of reasons, a top end rebuild may make more sense for you. You can tell if the problem is rings or valves sometimes by doing a compression test before and after adding a bit of oil into the cylinder. If compression improves after the oil is added (oil helps make a better seal at the rings) the rings are implicated; if not the valves are suspect. In the end it probably dosen"t matter. If you"re going to go to the trouble to pull the head and have it re-worked then replace, grind, or at least lap the valves AND replace the rings (don"t forget to hone the cylinder walls). Rings, and valves for that matter, are cheap, it is the time and labor that your machinist will put into the head that will be the big expense. Good Luck and keep us posted.
Home
| Forums
Today's Featured Article -
Show Coverage: Godfrey, Illinois Country Days - by Cindy Ladage. Except for last fourth of July's Old Gold show in Springfield, Illinois, I don't remember when it was so hot. Nevertheless, the heat didn't keep vendors and visitors alike from enjoying the third annual Country Day's Event. Jane Elliott said the event was originally a one man show. "Barry Seiler, owner of Country Town Farm Supply store used to invite people up to the Johne Deere store. He would give hats and a free meal for everyone that brings a tractor." Elliott said while this
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
