Re: IH 460 Gas ~ Engine Oil Capacity
Posted by K.B.-826 on December 28, 2005 at 11:23:35 from (24.180.146.111):
In Reply to: Re: IH 460 Gas ~ Engine Oil Capacity posted by skwhrle on December 28, 2005 at 08:14:20:
Kurt, I believe it holds 16 gallons of hyd. oil. Check plug is on the left side of the transmission case, fill through the opening covered by a small plate next to the shift lever base. Engine holds 9 quarts of low-ash oil. I can't stress enough how important it is to use low-ash oil in IH's 6-cylinder gas tractor engines. They are designed to allow oil to run down the valve stems, through the guides, and into the cylinders. Regular oil will cause the plugs to foul and will leave deposits on the valves which will prevent heat transfer, causing burned valves. Low-ash oil is avalible at your local Case-IH dealer, and most good farm oil suppliers should have a low-ash oil.
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
