Re: international 240
Posted by Jonathan Brown on December 30, 2005 at 06:58:36 from (69.245.180.63):
In Reply to: international 240 posted by randy on December 30, 2005 at 06:10:08:
I had a similar problem once on my cub, it turned out my intake manifold had a crack in it and was letting in air, the crack was small and could not be seen, I found it buy starting the tractor and squirting a little carb and choke cleanier on it, when I did the motor ran like it should have. just be cafeful remember you are using a flamable substance on a very hot part of the tractor. well I changed the manifold and that took care of the problem. thats my two cents, I am sure there is a safer way to check the manifold I am just not smart enough to know what they are. have a happy new year
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
