Re: Here I go again-MCV
Posted by the tractor vet on January 13, 2006 at 11:23:57 from (4.124.86.245):
In Reply to: Re: Here I go again-MCV posted by SGT K on January 13, 2006 at 09:33:01:
Well Ok here we go get your self a set of dial calipers and and IT manual as the spring FREE lengths are listed and the sump check plug is located BEHIND the MCV on the lower right hand side of the MCV in the range trans housing . Now if you have a good vice remove the lines and linkage on the MCV and drain the range transmission from the drain plug in it this will lower the Hdy fluid level but not the whole system remove the MCV from the tractor and place it in a vice and one at a time remove the valve and clean them one at a time and inspect them for any scoren or burs and with some carb cleaner sorta wash out that bore and with a littel compressed air blow out the bore then wet the valve with some clean Hy tran and see how it moves in that bore it should slide freely then check that spring for correct lenght you do not have a spring tester so as long as the spring is real close to the the correct lenght it will work . Now becareful when removing them as they will FLY OUT ( I just hate chasen springs across the shop. ) now you can also replace the pump also when you get to the steering orface make sure that nothing is blocking the hole .. Also mark what hole each bolt came out of and replace in the same hole and do not over tighten them . Let me know what you find . Good luck if ya get in over your head just yell .
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
