Re: Distributor timing on Super C
Posted by Janicholson on January 24, 2006 at 09:12:40 from (199.17.6.175):
In Reply to: Distributor timing on Super C posted by DFZ on January 23, 2006 at 13:52:26:
YOu probably did it correctly or it would have been many degrees off.
Check the timing (use manual or archives here), correct timing will improve efficiency and starting. Go for it.
JimN
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
