Re: Farmall 200 High Clear?
Posted by Hugh MacKay on February 04, 2006 at 20:25:10 from (216.208.58.109):
In Reply to: Farmall 200 High Clear? posted by Sloroll on February 04, 2006 at 16:41:40:
Slorol: I have seen a photo of one of these, and I'm thinking it has to be in YT photo galleries. Like the others I don't think it was factory, looked to me like 42" or 46" wheel designed to mount on the standard SC 36" wheel hub. It was wide front using about 19" wheel, same idea as you would see on AV or SAV
If you check photo gallery, I'm not sure whether you should look for C, SC, 200 or 230. I'm quite certain it was not a 240.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
