Re: H vs. 300 Weight...?
Posted by CNKS on March 05, 2006 at 14:28:01 from (204.249.178.138):
In Reply to: H vs. 300 Weight...? posted by Glenn FitzGerald on March 05, 2006 at 14:10:29:
Guy Fay's data book, which is about as accurate as you can get unless you actually weigh the two tractors says 3725 for the H, 4700 for the 300. These tractors, particulary the H are probably not fully equipped. The final weight depends on how many wheel weights at 145 lbs apiece, loaded tires or not, and other equipment. Easy to get an H to weigh 4500 lbs, 5000 not out of reach, add 500 or more lbs for the 300. 5500 for an H is a little steep, although not impossible. I have weighed my Super H, one set weights, no loaded tires, aftermarket 3 point. Exact weight escapes me, but it is close to 4500 +/- 100. Many of the books and web sites simply do not have the correct information, and really need to be taken with a considerable amount of salt.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
