Re: 460U
Posted by K.B.-826 on March 12, 2006 at 13:52:36 from (209.163.30.69):
In Reply to: 460U posted by Vally Farm on March 12, 2006 at 13:29:32:
Gas or diesel? Either way, a good block from a salvage yard should be no more than $500. Tons of them around. If it"s a gas, the C-221 engine would have been original, but you can use a C-263, C-291, or C-301 block. D-236 is the original diesel, but you could use a D-282 or D-301 block. I"d recommend staying away from the 301 blocks, as they are sleevless. As long as you are replacing the block, you might as well do a full overhaul, which could cost upwards of $5000 for a diesel depending on how much machine shop and fuel system work it needs. I would highly recommend having any engine work done by somone who really knows IH engines, as these early six-cylinders can be touchy about a few things, like how the sleeves fit into the block.
Today's Featured Article - Tractor Profile: Allis-Chalmers Model G - by Staff. The first Allis-Chalmers Model G was produced in 1948 in Gasden, Alabama, and was designed for vegetable gardeners, small farms and landscape businesses. It is a small compact tractor that came with a complete line of implements especially tailored for its unique design. It featured a rear-mounted Continental N62 four-cylinder engine with a 2-3/8 x 3-1/2 inch bore and stroke. The rear-mounted engine provided traction for the rear wheels while at the same time gave the tractor operator a gre ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
