Re: the alternator Search Hitachi
Posted by Janicholson on March 14, 2006 at 11:57:35 from (199.17.6.175):
In Reply to: the alternator, still not right? posted by Andrew Z on March 14, 2006 at 10:08:42:
From the archives (here)
I just finished doing this on my 1951 H with a lot of help from a couple of guys here on the forum. My alternator has the identity of each spade cast into the case. If you are following Bob Melville's wiring diagrams here on this site S is the same as the 2 terminal shown for the Delco 10SI alternator in his diagram. I just looked at my tractor and if you position the alternator with the two pivot lugs down the S terminal is the higher one and runs in a horizontal plane. Hope this helps. If you would provide your email address I have quite a bit of information I can provide to assist you in this conversion if desired. A really neat conversion for the H.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
