Re: SA axles tranny
Posted by kevinez on March 16, 2006 at 04:09:17 from (66.37.71.114):
In Reply to: SA axles tranny posted by banjo on March 15, 2006 at 21:33:47:
First off, if you don"t have one already, get a parts manual and a maint. manual. Invaluable information. Also, take plenty of pictures or notes. Helps when putting everything back together any you wind up wondering where that extra thingy went. To remove the axels you will first need to remove the brake drums. Loosen the set screw and slide them off. They have a woodruff key. I personally had a devil of a time getting the drum off of the long axel. Wound up having a round steel plate made with threaded holes and some long threaded rod to make a puller. After much soaking, tighting and tapping on the top of the puller it finally came loose. Once the brake drums are off you should be able to slide the axel out of the housing. If the bearings are tight on the axel just tap them out with a hard rubber mallet. When I rebuilt the transmission I removed the differential cage first. When you remove the bearing retainer for the differential keep all the shims separate and marked for which side they go on. Then remove the top front bearing cover and tap the spline shaft back though. The rear bearing may work out of its seat. Pretty much the same with the countershaft if I remember correctly. Good luck.
Home
| Forums
Today's Featured Article -
Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
