Re: Flat rear tire on Farmall A
Posted by souNdguy on March 23, 2006 at 07:39:15 from (12.65.156.146):
In Reply to: Flat rear tire on Farmall A posted by Larry Ed on March 23, 2006 at 07:24:06:
I'll assume you have tried to air it already. now if it is tubeless.. you can wet the tire down a,d then try to find the puncture, and then patch with a plug. If it is tube style, then you will ahve to break the tire down. I imagine you have 2 choices.. either take the rim off and leave the center on the hub.. or take the whole assemby rim and center off. ( I guess some wheels are 1 piece.. not sure about yours.. ). Once you have it off, you will need a couple tire irons.. I like spoons.. a short and a long one, perhaps one with a step or a 'titt' on the sfaft to help you work the casing off the rim. While you could patch the tube.. I'd just get a new one. If the puncture hole in the casing is rough.. try to trim it up, and put a farm patch on the inside of the casing.. or cut up your old tube to make a boot for the damaged area. If the rim is rusty, sand / wire wheel / sand blast the rim inside, then paint with a good epoxy mental paint.. or rusty metal paint... allow you fully cure. Use only vegi based soap for lube when you reinstall the tube... and be carefull not to pinch it. A valve stem fishing tool will also be usefull. Alternatelyy, you can take this down to your local tire place and let them do it.. most places don't charge much to break down and re bead a tire.. Soundguy
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
