Update
Posted by Truck on March 29, 2006 at 20:26:51 from (64.12.116.65):
In Reply to: Saved an H from the scrap man.. But it is stuck..? posted by Truck on March 28, 2006 at 17:27:06:
Well, I went to pump the tires up today to drag it home and discovered the air/calcium adapter in one tube had corroded away. Ordered a new one at NAPA and hope I can make it seal long enuf to get it home.
Stupid question.. Where the "H" is the dipstick for the engine in this thing? I found a petcock on the oil pan, it had nice black oil in it at that level, no water.
Good thing tho...the ring chains are still on it. They are worth what I paid for the tractor!I think I'll pop them off before it goes for the little drive up the street.
I promise I won't pop the clutch. Today I found out the muffler has been off most of the last three years,even tho it was on when I went to look at the tractor. I think it will be a soak it for the duration project. Wish I could find that turpentime I had found somewhere this summer..
THanks for all the info guys!
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
