Re: Slow cranking M
Posted by captaink on April 04, 2006 at 06:49:50 from (66.115.214.56):
In Reply to: Slow cranking M posted by MarkCo on April 03, 2006 at 18:19:03:
Others have told how to keep the 6-volt up and going. To convert to 12 you will need a battery, a resistor (or coil that is 12-volt ready), new light bulbs (or new lights), and an alternator (or 12 volt generator). If it hasn’t already been done, I also recommend changing the push button starter switch to a remote solenoid with a secondary terminal that is live only when the solenoid is engaged. If you do chane to a solenoid, you will need a push button or an ingnition swith to operate it. You do not need a starter as the original one will function just fine on 12-volts. Unless you want to keep the tractor original, I strongly recommend converting to 12 volts. A Delco 10si alternator is very popular, however I believe that there is a Hitachi alternator that is popular also. Both will fit under the hood with no modifications to the hood and slight modifications to the mounting brackets. I mount the resistor and the solenoid on the battery side of the rear fuel tank bracket out of the way. This also allows a short wire to run from the starter solenoid (or switch) to the coil side of the resistor to provide a 12-volt start/6-volt run system. I have converted all my "working" tractors to 12 volts (B, C, 2 Ms)and a couple older vehicles and have NEVER regretted it. Starters stand up, engines start fast and few if any times do I have problems with starting. If you work at night you have brighter lights, and you can add a power point if you want to power any modern accessory you may want to add. Besides that, batteries can be bought from any place that sells 12-volt car batteries. Benefits many, the only drawbacks I can see is it’s not stock anymore (it’s up to the owner if this is an issue or not) and the hand crank mechanism in the front bolster will probably rust tight(er) from non use. :>)
Home
| Forums
Today's Featured Article -
Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
