Re: electrolosis derusting an engine block questio
Posted by Turk on April 22, 2006 at 13:01:27 from (199.184.119.22):
In Reply to: electrolosis derusting an engine block question posted by Jonfarmer on April 22, 2006 at 12:36:59:
Hi JF, get the washing soda, I use Arm&Hammer. A lot of places do have it. Seems like you use baking soda to remove paint? I does not matter how much water you have as long as it is submerged. I use a pound for fifty gallons. I use a big sacrificial anode, and in your case something that wraps around the inside of your barrel would be dandy, you can get a lot of surface area and get away from the line of sight deal. You may want to use smaller anodes inside but not touching the block to get good coverage. Try moving the anode around in the tank to find the spot that draws the most amps. In my opinion if you are only pulling six or eight amps you can do it faster with a wire brush. More amps equals less time. I cleaned one whole engine that was rusted solid, had been buried for who knows how long. It drew between 40 and 90 amps for three weeks, but when it came out it was disassembled in 30 minutes with no breakage whatsoever. Remember when it is drawing a lot it is also giving off a lot of hydrogen, so vent accordingly. Play with it a little and you will swear by it.
Today's Featured Article - The River Tractor - by Charlie English Jr.. This is a 4010 John Deere that was used to farm on the Diamond Island which is in the Ohio River about 15 miles southwest of Evansville, Indiana. About ten years ago, this tractor was parked close to the bank as the river was washing the bank of the island away. ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
