Re: Need you help
Posted by old on April 26, 2006 at 12:13:39 from (207.69.137.25):
In Reply to: Re: Need you help posted by Kevin Schumacher on April 26, 2006 at 10:20:51:
Remove the air intake tybe going to thew air cleaner. Put your hand over the end of the carb. Does it suck on your hand and does your hand get gas on it?? If it doesn't suck much you may have a problem with a manifold leak. I've had more then one that woud fire up but when I did that it would fire up and run from thenm on. What the does some times is pull crude out of the fuel system and clears things up
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
