Re: Solid State Ignition
Posted by John T on April 27, 2006 at 07:20:44 from (66.244.90.5):
In Reply to: Solid State Ignition posted by Allan In NE on April 27, 2006 at 03:13:43:
Allan, No, you could get by with an existing stock coil (if voltages and any ballast etc is correct) and gain at least some spark gap energy (faster more positive switching) using an electronic switch versus the old mechanical points, but to get the most bang for the buck that elec switch has to offer and realize more spark gap energy for better ignition, I HIGHLY RECOMMEND you couple the new elec switch with a high energy high voltage coil the vendor offers to match the new switch. Using a high energy high voltage coil and an electronic switch, one often runs a tad wider spark plug gap also. Next, be sure to match the new coil with the switches current capacity as I believe some switch vendors offer different switch ratings dependant upon what coil is used. As far as wiring, all thats usually involved is two wires out of the unit mounted in the distributor base to replace the points that run one to each side of the coil, piece of cake to wire. A magnet fits down over the distributors cam shaft lobes which triggers the switch. The existing switch and wiring to the coils input (regardless if new or old coil) ought to suffice provided its all in good condition. NOTE If a high voltage coil is used and youre running a wider plug gap, good plug wires and a good distributor cap etc must be used.......... Check with the vendor as far as plug wire recommendations cuz some of those high performance systems actually use carbon core plug wires which I would not use otherwise. NOTE is this 12 volt system?????? If so although its still possible to use a 6 volt coil and an external ballast resistor, I highly recommend use of a 12 volt coil and do away with the ballast. CAUTION these units are polarity and voltage sensitive, BE SURE and buy a unit to match your ground,,,,, your voltage,,,,,,,,and a coil suitable for the switches current rating. Hope this helps, let us know John T
Home
| Forums
Today's Featured Article -
Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
