Re: I've been given an H
Posted by old on April 27, 2006 at 08:07:00 from (207.69.137.9):
In Reply to: I've been given an H posted by Jugum65 on April 26, 2006 at 21:59:52:
Couple of things to do first. Pull the oil drain plug from the engine and have a look see what might be in there. If you find a bunch of junk up in there when you try to drain it pull the pan. Is the engine loose or locked up?? Either way I would fill the cylinders with tranny fluid to help brake things loose, the rings even if the engine turns are probably sticking to the pistons
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
