Re: Char-lynn power steering
Posted by Bob M on April 29, 2006 at 19:46:42 from (69.205.125.67):
In Reply to: Char-lynn power steering posted by super99 on April 29, 2006 at 16:22:10:
Chris - Sounds like either you have weak pumps or the steering pump relief valves are set too low (that may be the "squealing" you're hearing...).
FWIW my SM has Charlynn power steering supplied by a priority valve off the live pump. It steers easier than my wife's car regardess of engine RPM, ground speed or load on the front wheels.
Regarding wetness around the steering motor check the two motor hose manifold cap screws for tightness. They tend to work loose over time which results in seepage that appears to be coming out of the motor itself.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
