Re: '40 H transmission
Posted by Shovelman on May 16, 2006 at 05:21:54 from (68.191.57.27):
In Reply to: '40 H transmission posted by RD/oh on May 15, 2006 at 16:38:13:
The input bearing housing/shaft assy can be removed without splitting the tractor or pulling the top cover, but it is tight, especially if the tractor has a belly pump. Before you start, check the bearing play in the input shaft. Also, check for oil leakage at the brake housings. If there is, remove the covers and check the brake drum bearings for looseness. If there is, take the time to pull the top cover and check everything out. There is a small roller bearing mounted on the end of the pinion shaft which rides on the inside of the input shaft/gear. It is caged, but when it gets worn the rollers will fall into the trans. case when you remove the input shaft, requiring you to pull the top cover off and fish out the pieces anyway. The pinion shaft ball bearing sometimes requires replacement, and the top cover has to be off to do it. Note: If you have to pull the bearing housings located behind the brake drums, be sure remove the bull gears BEFORE pulling the bearing housings. You will break the bearing housings if you don't pull the bull gears first. Splitting the tractor is not that bad. It can be done in less than an hour. We just went through the transmissions on both of our H tractors, so if you need bearing or seal numbers, etc., let me know. Good luck, Scott Check our website:
Home
| Forums
Today's Featured Article -
A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
