Re: B Overheating???
Posted by gene bender on May 18, 2006 at 16:43:55 from (66.43.221.211):
In Reply to: B Overheating??? posted by jenglin on May 18, 2006 at 10:15:31:
Chances are the block is blocked at the base of the sleeves as there are small holes the size of a nickle where the water comes thru to the radiator. I would pull the radiator and the lower housing on the block then using compressed air and water get the junk out of those holes. You can see in there with the lower outlet off. mite want to back flush also. It is not uncommon to find sludge deep in this area when replacing the sleeves. You can also add a water pump easy as it will bolt on where the lower housing is now and just add a longer belt. Just be sure to get a pump with a pulley as some do not come with pulley. The pump is tyhe same as used on SCs
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
