Re: 1961 Cub Drive Train
Posted by Janicholson on June 25, 2006 at 13:32:08 from (66.173.50.28):
In Reply to: 1961 Cub Drive Train posted by mimnpipd on June 24, 2006 at 20:16:51:
The engine may not be stuck, but you did not say it runs. If it is not running. Then you may not have let out the clutch with it running. The front bearing in the trans could be rusted, or self destructed. The counter shaft may also be on a bad bearing. Neither of these turn when in neutral. If you can hand crank the engine with the trans in neutral and the clutch out, it should be able to be pushed in neutral as well. (from your description)
If it will not turn by hand cranking in neutral, the top of the trans needs to come off. (my opinion) A service manual is mandatory before taking the top off.
JimN
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
