Re: before pic of alt
Posted by Bob on July 10, 2006 at 22:09:17 from (64.21.249.40):
In Reply to: before pic of alt posted by budaa on July 10, 2006 at 21:15:40:
The alternator you got is a "one wire" unit, and doesn't need the "switched excite" wire to it's #1 terminal, and the "voltage sense" wire from the large output stud to it's #2 terminal, so those terminals are covered with the black rubber plug.
The alternator WILL charge with just the large output wire connected, but, likely, the engine will have to be revved up somewhat, after each startup, for it to begin to charge (excite).
Some of us prefer the "OEM-type" 3-wire setup like you HAD, but the goofy "one-wire" units always seem like the "cat's whiskers" to the "electrically challenged", as Dell likes to say, over on the "N" Ford Board.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
