Add on hydraulics
Posted by Chad Enyeart on July 12, 2006 at 08:43:56 from (208.3.139.26):
I have a super C with the factory cultivator lift system on it. I purchased one of those blocks that you put between the steel lines to and from the pump and the hydraulic system. Here is the questions that I have for you. Should I use an open center or closed center hydraulic valve for the loader that I am putting on? Should the flow be in series or what. I might be over thinking this but any help that you can provide would be greatly appreciated.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
