Re: Help with new Farmall H
Posted by williamf on July 14, 2006 at 16:59:19 from (69.19.14.24):
In Reply to: Help with new Farmall H posted by Lincoln on July 14, 2006 at 16:31:50:
It's not live hydraulics. The power from the pump (the brand name is "Liftall") comes back from the transmission; if the clutch pedal is depressed the pump's not pumping. Takes some getting used to. All three outlets are supplied from the same source - the one lever works them all. The one on the right and the front one on the left move first and when the cylinders they're pushing reach their limit a (similar to a relief) valve opens to supply the rear outlet on the left. Anything more complicated you have to add valves and plumbing. Some people add a spool valve on one of the outlets and keep the lever pulled back for a steady flow. If you want to get a really in depth explanation IH published an excellent manual for the Liftall unit. You can get one from the good people here at YTMag. http://www.ytmag.com/cgi-bin/store/mansrch.pl Good luck with your H, Wm
Home
| Forums
Today's Featured Article -
Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
