Re: Check compression on Farmall M
Posted by CNKS on July 14, 2006 at 19:52:52 from (204.249.178.138):
In Reply to: Check compression on Farmall M posted by Don L C on July 14, 2006 at 16:03:42:
Remove all the plugs, use a compression gauge in the spark plug hole, and spin the starter. Do it first dry, them squirt motor oil in each cylinder and do it again. If the compression dry is low and increases significantly wet, you have a ring problem. If it is somewhat low and stays the about the same, the valves are leaking. More important than the actual numbers is the difference -- the cylinders should be within 10% of each other. If you have a gasoline engine with standard pistons, the original compression was about 120. How much less than that you can go and still have a decent engine, I don't know. IMO, 90-100 is good, 80 questionable. Others will have different opinions.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
