Re: Farmall H head gasket replacement question.
Posted by K.B.-826 on July 25, 2006 at 16:09:40 from (66.188.211.45):
In Reply to: Re: Farmall H head gasket replacement question. posted by Bleys on July 25, 2006 at 14:47:59:
When I torque down heads I like to do it in three steps. Oil the threads and start out with the bolts a little more than finger tight, then in this case I would torque them to 35 ft lbs in sequence, then to 70 in the same sequence, then to 110 in the same sequence. Then run back over them at 110. Once you've had it up to temp and under a load, wait until it's cool enough to work on but not totally cold, and in the same sequence, crack each bolt loose and take it right back to 110 one at a time. Run back over them without cracking them loose and you're done. I've done this on countless engines and have always had good results.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
