Re: farmall A gear wine niose
Posted by Dave BN on July 29, 2006 at 19:05:52 from (64.12.116.65):
In Reply to: farmall A gear wine niose posted by brent schneider on July 29, 2006 at 18:11:10:
Those transmissions and final drives do make a whining noise. I would change the transmission fluid. The drain is in the rear, under the PTO shaft and the fill plug is by the shift lever. The level check is a pipe plug on the left side of the tranny behind the brake rod. You should also change the fluid in the final drives by removing the pans at the bottom to drain the fluid and clean the pans out. Put them back on with new gaskets and fill thru the level check plug which is just above the pan gasket. 2 gallons of 85W90 should be all you need. Dave.
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
