Re: F12 can't get 'er to start fer nothin'
Posted by El Toro on September 06, 2006 at 06:01:55 from (64.12.116.65):
In Reply to: F12 can't get 'er to start fer nothin' posted by holt_2ton on September 05, 2006 at 16:19:47:
Make sure your plug wires are copper wire and aren't the resistor type wires. Bring No1 piston to TDC on the compression stroke and then remove the cap from the mag and see where your rotor is pointing. Should be at the No1 plug tower. If it is, remove the coil wire from the cap and hold within 1/8-1/4" of a good ground while someone hand cranks the engine. Should have a hot blue
spark. You may have a weak coil if the spark is weak or the magnets may have lost some of their magnetism. Hal
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
