Re: power steering not working
Posted by the tractor vet on October 04, 2006 at 08:59:05 from (75.24.28.38):
In Reply to: power steering not working posted by leodis on October 03, 2006 at 12:40:39:
Well the two things that come to mind is either your MCV pump is going to lunch or ya have a problem in the MCV with a sticking flow divider or a pressure reg. problem or a blowen MCV gskt. or O/ring . And if you have been playen around with the MCV then this leads me to a blowen gskt. or O/ring But with out me looken at it myself we are guessen . Rebuilding a MCv is not that hard if ya got a book and a real clean work area a good vice to hold the valvebody in and a set of dial calipers to massure the spring lenghts with and some fine emery to polish up the spools as they must slide freely in there bores and alway use the same thickness gskt. that it mounts to the transmission housing and make sure that you install a new O/Ring on the pressure port on the transmisson housing and do not loose the littel spring for the sump check plug on the lower right hand corner . If you are not comfortable with doing it then take it to someone that knows what he is doing . as this will reduce your stress level.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
