Re: Help identifying voltage regulator poles
Posted by Bob M on October 06, 2006 at 06:37:58 from (151.190.254.108):
In Reply to: Help identifying voltage regulator poles posted by Matt Williams on October 05, 2006 at 19:59:41:
Hey Matt - If you have an ohmmeter you can use it to figure out which regulator terminal is which. Set the ohmmeter to it’s lowest range (ohms x 1). Connect one test lead – doesn’t matter which - to the regulator base. Then test each regulator terminal with the other test lead. Results should be as follows: F (or FLD) – ~0 ohms G (or GEN) – several ohms B (or BAT) - open circuit (infinity) Obviously the remaining terminal will be the L. --- Additional tests: 1 - Remove the regulator cover. You should find two relays inside. 2 - Attach one test lead to the regulator base and connect the other to the F terminal. Now push the voltage regulator relay armature down (the voltage regulator is the relay whose contacts are held SHUT by spring pressure). The meter should read several tenths of an ohm with the contacts held manually open. 4 - Connect one test lead to G terminal and the other to the B terminal. The ohmmeter should indicate open circuit. Now manually push the cutout relay down (the cutout's the the relay whose contacts are held OPEN by spring pressure). The meter should read ~0 ohms with the cutout contacts held manually closed. --- Note: It's possible your regulator has only 3 terminals (ie. the L is missing). If so simply connect the ”orphaned” wiring harness L wire to the B (or BAT) terminal on the regulator. Hope this helps...
Home
| Forums
Today's Featured Article -
A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
