Re: Help identifying voltage regulator poles
Posted by John T on October 06, 2006 at 06:43:35 from (66.244.90.5):
In Reply to: Help identifying voltage regulator poles posted by Matt Williams on October 05, 2006 at 19:59:41:
Matt, if theres reallyyyyyyyy only 3 terminals, and its realyyyyyyyy a Voltage Regulator (versus a cutout relay only) they would be BAT ARM and FLD i.e. a 3 terminal VR VERSUS a 4 terminal (BAT FLD LOAD ARM) VR as many used originally. Its possible to use EITHER as a replacement regardless how she was set up originally with only a couple minor wiring changes, heres the deal: NOTE on many 4 pole, the BAT FLD LOAD terminals are together while the ARM terminal was off on one side all by itself or the bottom, sure theres no 4th terminal hid on the bottom ??? If it was originally a 4 pole VR, the hot voltage feed for Loads like lights and Ignition was suppled from the L terminal on a 4 pole VR. HOWEVER if you wanna use that 3 pole VR, the voltage feed for Lights and Ignition (what used to wire to L on a 4 pole VR) can then be fed off the VR's BAT terminal instead or else directly up behind the dash by a wire off the ammeters load side terminal, being the SAME terminal that wires to the BAT terminal on a VR (3 or 4 pole). If the wiring harness was originally for a 4 pole VR with TWO not just one wires up to the dash, just conenct the load wire (feeds lights n ignition) over to BAT on the VR since theres no L terminal to hook to on your 3 pole VR WITH THE VR STANDING ALONE NOT CONNECTED TO NUTTIN Now as far as those unlabeled terminals, one of them (the FLD terminal) should show very low resistance between it and the VR's metal mounting case/frame. If you find which terminal shows low or no resistance to the metallic case where she mounts, label it Field (FLD) and it wires to the Field post on the Genny. The other 2 terminals would be BAT and ARM (or GEN) and there should be an like a very high (Open) resistance measured between them. Between those 2 terminals (BAT and GEN/ARM) theres a Cutout Relay which is normally in the open (or very high resistance) position but once the gennys output voltage rises higher then battery voltage, the relay closes so the gennys output (its ARM terminal) can get to n be connected with n charge the battery (out the VR's BAT terminal) but when the tractors shut down that Cutout Relay (between BAT and ARM/GEN VR terminals) opens so the battery dont reverse discharge through the genny. Soooo just sittin there not hooked to nuttin the Cutout Relay should be in the OPEN position (very high resistance) since it shouldnt close until it senses voltage on the ARM/GEN terminal. BAT on VR wires to the ammeters Load side terminal FLD on VR wires to the gennys Field post ARM/GEN on VR wires to gennys Arm post Loads like lights n ignition wire to the BAT terminal on a 3 pole VR or else the ammeters load side terminal being the same terminal that wires to BAT on the VR. NOTE N CAUTION one thing confusing is did you mean theres only one coil/relay inside the unit??????????? Cuz a simple Cutout Relay has but one coil/relay inside,,,,,,,, while a VR (3 or 4 pole) has at least 2 n sometimes 3 coil/relays inside. Also on some simple cutout relays, theres still only one coil/relay inside although they have an extra 3rd lil external terminal. The simple cutout relays used the light switch (L H B D) as the field curent control system by having the gennys Field post wire to the light switch instead of any FLD terminal like on the VR syatems. I cant tell sitting here what you really have, a simple Cutout Relay or a VR, so Im hesitant to describe the wiring butttttttt if theres only one coil/relay inside it Ima thinkin it a simple Cutout Relay............ Maybe digest all this n look closely at the VR or Relay or whatever it is you have and tell us more or if we had pics n we will go from there. NOTE Bob M and Bob are more familiar with this IHC stuff then me (Im a John Deere man) since I havent owned them for years so if they tell you different then me believe them buttttttt as far as I know still alllllllll I posted above is accurate, they may have more IHC cutout relays or VR's laying around (I have NONE) to look at n compare n guide you better then me cuz sorry, I just cant tell from sittin here not seeing or knowing any resistance values or how many coil/relays are inside that unit to know what you really have, maybe they can????????? Best wishes n God Bless yall, sorry no definite answer here but the above may still help figure it out John T
Home
| Forums
Today's Featured Article -
Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
