Re: Farmall 130 rocker pins
Posted by SuperA-Tx on October 17, 2006 at 12:57:06 from (4.90.5.89):
In Reply to: Re: Farmall 130 rocker pins posted by Hugh MacKay on October 17, 2006 at 12:07:26:
I checked on those pins (Rockshaft Clevis Pin, part #350 142 R1) a month ago. They are now up too $20.00 each. Yes, thats right, TWENTY dollars each at Case!
The "Rockshaft Clevis Pin Lock" (clip) that holds the pins in were $26.00 each at Case.
Small pin was $2.17 and the spring was $4.28
I made mine myself out of 1/2" x 3" hex head bolts. Cut them off and grind the head down. Cost about $1 not including the labor. Turned out so good my cousin had me make him some and then made some for a friend.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
