Farmall Tractors Discussion Board
IHC Model Configuration Chart
Posted by Harold H on January 29, 2000 at 07:36:59 from (207.244.55.141):
for the Letter Series Era
Row Crop Row Crop Wheel Industrial Other Crawler
Hi-Clear Standard
F-Cub none none I-Cub Cub none
Lo-Boy
F-A F-AV none I-A none none
F-B none none none none none
F-BN
F-C none none none none none
F-H F-HV W-4 I-4 O-4 none OS-4
F-M F-MV W-6 I-6 O/OS-6 T-6
F-MD F-MDV WD-6 ID-6 OD/ODS TD-6
-6
none none W-9 I-9 WR-9 T-9
WD-9 ID-9 WDR-9 TD-9
none none MRS-14 none none TD-14
(not IHC)
none none MRS-18 none none TD-18
(not IHC)
none none none none none TD-24
This chart gives each configuration of each basic size tractor, starting with the base model on the left side, during the letter series era. I included two MRS tractors because they used IHC engines and components and the same Lowery IH styling and filled a missing gap in the standard/wheel tractor lineup. During the letter series era, all rowcrop and hi-clear tractors were FARMALL. All wheel type or standard type tractors were McCORMICK DEERING (39-44) or McCORMICK (late 44-on), all industrial tractors were INTERNATIONAL, all orchard type tractors were McCORMICK DEERING or McCORMICK, all crawler Trac-Trac-Tors were INTERNATIONAL. The chart can easily be updated by placing the updated model on the left and charting its different models across the table such as M-SM-400-450-560 for a base model that ends with the TD-6. I just posted this chart for general information, interest or comment.
Harold H
Post A Followup
: Re: IHC Model Configuration Chart
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
