Adjusting TA
Posted by mulcher on October 18, 2006 at 17:42:25 from (63.163.138.206):
Did the adjusting of the TA on my 1586 after reading old posts on here and reading the IT manual for my 1086. Got the snap ring set down snug and added a half turn. When the plunger comes up and there is suppose to be 1 1/8" I only have 7/8". Is that OK? Had trouble setting the dump valve also like the book says. Have it now so lite goes off just before clutch engages. Also set free play and trans brake.
The 1086 will almost lift the front wheels off the ground when you shift to direct but the 1586 is lot slower shift and smoother and made me wonder which is right?
Enjoy reading all the posts.
Brian
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
