Re: Oven cleaner on engine block
Posted by jmixigo on October 20, 2006 at 16:51:27 from (69.73.54.156):
In Reply to: Oven cleaner on engine block posted by Dave Register on October 20, 2006 at 16:21:12:
If you use oven cleaner, rinse alot then wash down with straight vinegar, scrub with a brush and rinse a lot more.
Oven cleaner will also destroy any thing made of brass or aluminum.
Gunk Engine Brite, Purple Power, wire brushes, an a putty knife should also come in handy.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
