Re: H rear wheel wobble
Posted by riverbend on November 13, 2006 at 19:44:25 from (208.160.33.109):
In Reply to: H rear wheel wobble posted by dakotaclassic on November 13, 2006 at 15:08:17:
I'll give you $300 for it if you bring it over.
The biggest problem is that the shards of the bearing fell inside the rearend. the big stuff will settle to the bottom, but the little stuff will get circulated through the rest of the bearings.
Like anything on an H, it is an easy repair. You just have to remove the top cover to make sure that everything is clean. I spent about $500 to replace all the bearings in the transmission on my H.
Greg
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
