Re: super a runs rotten
Posted by old on December 06, 2006 at 06:01:17 from (4.244.6.214):
In Reply to: super a runs rotten posted by rch on December 06, 2006 at 05:16:12:
Sounds like its running on the lean side to me. What happens if you choke it at the same time your opening up the trottle?? If chokeing it helps then you have a problem with the carb and either the main jet is dirty or needs adjusted if it has an adjustment that is. If it doesn't have an adjustment you might try pulling the drain plug and pulling the main jet cap and spraying carb cleaner into the main jet to clean it. I have to do that once in a while on one I have that doesn't have an adjustable main jet
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
