Adding hydraulic output to 340U
Posted by PaulW_NJ on February 05, 2007 at 08:31:43 from (70.111.136.152):
My 340 Utility has two sets of hydraulic outputs on its sides that are controlled by HydroTouch valves (used for loader), and hydraulic lines running back to the Fasthitch, with it"s own TeleDepth control lever. I would like to add a set of hydraulic outputs back to the rear to attach to a hitch mounted log splitter attachment (shown in Northern Hydraulics: it comes with it"s own control valve). The 340"s external hydraulics pump is rated at 9 gpm at 1500 psi which is not terrific for a log splitter but may be sufficient. Can anyone tell me what would be involved, and where you"d tie in, to add that capability? Has anyone else tried this?
Thanks
Paul
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
