Re: Hydraulic fluid level and maintenance for 140
Posted by Hugh MacKay on June 30, 2007 at 19:47:15 from (209.226.247.184):
In Reply to: Hydraulic fluid level and maintenance for 140 posted by Tab on June 30, 2007 at 18:59:50:
Tab: The tractor rockshaft arms at the fuel tank must be in rear position both for adding to or filling the hydraulic system. You then fill to the bottom of the fill hole. At the bottom left of the touch control unit, is a cover held in place by 4 small bolts. About 3" kind of rounded square. Behind that cover is a cylinder type screen, designed to stop dirt from going to the pump on the suction side. That screen must be cleaned regularly. You will loose a bit of oil when you remove the screen. Always use Hy tran or it's equivilant in the hydraulic system. If your disk is a 20 blade tandem that is just about the load limit of that hitch, and yes it will make the front end light. Since you are asking these questions, you must not have a manual. You should have an IH operator's manual at least. I can assure you that without a manual you have other lubrication points going unserviced.
Home
| Forums
Today's Featured Article -
Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
