Re: 656 PTO lever leaking fluid.
Posted by Owen Aaland on July 17, 2007 at 14:42:25 from (65.165.246.40):
In Reply to: 656 PTO lever leaking fluid. posted by Scott(MO) on July 16, 2007 at 19:00:06:
The shaft seal is the only thing that keeps the oil from leaking. Make sure the stem is not rusted or scored. You will need to reset the pressure after replacing the seal. The valve assembly must come out the bottom but you can replace the seal from the top. Check back to 07/11/07 to see a simular discussion dealing with a 756. You have the same type of PTO.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
