IH 424 Gas Misting out of Gas Cap
Posted by Chris Hibbert on July 22, 2007 at 10:57:45 from (24.106.231.115):
On my '67 424 Gasoline, when I drive around on varying terrain, gasoline blows out past the seal on the gas cap. The gasoline isn't coming out of the vent holes (2) but at the mating surface where the cap screws tight onto the tank. First guess would obviously be that the gasket on the gas cap is worn or missing but this is a brand new cap directly from IH. The reason I got this cap is that the previous one did the same thing (it looked old but also had the two vent holes in it). Is it possible that the mating surface on the tank itself is worn thin enough that the new gasket doesn't seal properly? When I put the cap on, it's pretty tight when you turn it all the way. Should I take the gasket from the other cap and double them up? Or. . . . does this point to a problem elsewhere?
Thanks in advance for your help!
Chris Hibbert
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
